I have destroyed my spinnaker pole in a slam dunk jibe. The fittings are all OK but need a replacement extrusion. Dimensions: Overall length: 11' 9" (includes end fittings); O.D. 2 7/8", I.D. 2 3/4". Have tried several places unsuccessfully. Does anyone know where I can find one?
[I can think of lots of places, but their suitability really depends on where you are - Toronto? Nunavut? The Solomon Islands? This is one of the reasons - aside from idle curiosity - that we put the location field on our registration page. Tell us where and we might be able to give you an answer that will do you some good. - Admin]
Sorry about that! I'm located in Ottawa (Britannia Yacht Club). The extrusion is an odd size. I can get 2 1/2" or 3" unanodized locally but I'm hoping to find the right size so that I don't have to adapt the fittings.
Try locating a spinnaker pole for a J-30 or similar and trim one end back and re-rivet...... the pole for the 27 is a bit heavy anyways...
1975 C&C 27 MKlll
Hull No 453
Kittery Point,Maine
Last year I bent my whisker pole during a blow while white-sailing and I did a temporary 'splice' in the bent portion by machining down a piece of Aluminium pipe to suit the diam. in a friend's lathe and I made-do for the rest of the season with the balky extendable pole, however the pole was actually "toast".
This winter I found this place (<A href="http://www.mapleleafcom.com/alum.htm)">http://www.mapleleafcom.com/alum.htm)</A> and here I was able to buy Aluminium tubing in two 'nesting' diameters, so I scavenged the fittings from the old pole, installed them on the tubing I bought and voila, a "new" pole for under $50.00 ( The Chandlery wanted just under $500.00 for a replacement pole !!!).
I don't know if 'Maple Leaf' stock (or could get you) the right diameter aluminium but this place located north of Toronto, gave me great service.
Clare Jordan
<U>SAIL FOR SALE </U>_
Hi Mike. Presume you've tried Ridalco (used to be Rideau Aluminum Co.) on Michael St (parallel to St. Laurent off Belfast). They carry a broad range of tubular stock and if they don't have the right size, they'll perhaps point you in the right direction. Good luck.
Thanks for the info: however, I tried them and unfortunately their largest size is too small for this application. Will keep looking! Thanks!
I tried Ridalco but they just laughed when I mentioned the dimensions. I might try getting 3" tubing and manufacture adapting collars for the end fittings using the remains of the existing pole. Thanks!
