#1 2006-05-31 03:48:16
Spinnaker Pole for Mark 3
I have destroyed my spinnaker pole in a slam dunk jibe.  The fittings are all OK but need a replacement extrusion.  Dimensions:  Overall length: 11' 9" (includes end fittings); O.D. 2 7/8", I.D. 2 3/4".  Have tried several places unsuccessfully.  Does anyone know where I can find one?
[I can think of lots of places, but their suitability really depends on where you are - Toronto? Nunavut? The Solomon Islands? This is one of the reasons - aside from idle curiosity - that we put the location field on our registration page. Tell us where and we might be able to give you an answer that will do you some good. - Admin]
#2 2006-06-01 00:48:54
Re: Spinnaker Pole for Mark 3
Sorry about that!  I'm located in Ottawa (Britannia Yacht Club).  The extrusion is an odd size.  I can get 2 1/2" or 3" unanodized locally but I'm hoping to find the right size so that I don't have to adapt the fittings.
#3 2006-06-01 01:13:05
Try locating a spinnaker pole for a J-30 or similar and trim one end back and re-rivet...... the pole for the 27 is a bit heavy anyways...
"IRIS"
1975 C&C 27 MKlll
Hull No 453
Kittery Point,Maine
#4 2006-06-01 03:08:04
Aragorn
Last year I bent my whisker pole during a blow while white-sailing and I did a temporary 'splice' in the bent portion by machining down a piece of Aluminium pipe to suit the diam. in a friend's lathe and I made-do for the rest of the season with the balky extendable pole, however the pole was actually "toast".
    This winter I found this place (<A href="http://www.mapleleafcom.com/alum.htm)">http://www.mapleleafcom.com/alum.htm)</A> and here I  was able to buy Aluminium tubing in two 'nesting' diameters, so I scavenged the fittings from the old pole, installed them on the tubing I bought and voila, a "new" pole for under $50.00 ( The Chandlery wanted just under $500.00 for a replacement pole !!!).
   I don't know if 'Maple Leaf' stock (or could get you) the right diameter aluminium but this place located north of Toronto, gave me great service.
  Clare Jordan
#5 2006-06-01 23:35:20
Hi Mike. Presume you've tried Ridalco (used to be Rideau Aluminum Co.) on Michael St (parallel to St. Laurent off Belfast). They carry a broad range of tubular stock and if they don't have the right size, they'll perhaps point you in the right direction. Good luck.
#6 2006-06-03 02:17:10
Thanks for the info: however, I tried them and unfortunately their largest size is too small for this application.  Will keep looking!  Thanks!
#7 2006-06-03 02:19:47
I tried Ridalco but they just laughed when I mentioned the dimensions.  I might try getting 3" tubing and manufacture adapting collars for the end fittings using the remains of the existing pole.  Thanks!
