For keeping halyards out of the way, I obtained mesh bags to mount on the cabin surface next to the hatch. The mounting method was suction cups ( to avoid drilling more holes) but these were inadequate. I then tried velcro sticky back strips, but these are not holding well. One of my crew recently owned a C&C35 and his solution was a bag that had grommets like those in sail covers and the "male" ends are then mounted into the interior cabin roof section which has a vertical face where the sliding roof rails are mounted. So drilling holes there are less of a problem. And the bags and excess halyards are out of the way and not just dangling inside the cabin.
So, the question is- has anyone done this on a Mark V? Are there other solutions to halyard storage?copasetic
I too, have been looking for a better way to store these lines, both when underway and in the slip. I'd really like to see some photos, if that's possible.
Tony Jeske
Mk V #581
FLYING CIRCUS
San Diego
I have three expandable bags on each side of the narrow vertical section immediately below the sliding hatch. They are mounted on a rectangular piece of rigid canvas which is held in place by four press studs ( pop studs?)along its top edge, the male section of which is attached to the boat by Philips-headed screws. The press studs are heavy duty and easily hold the weight of the lines/sailing gloves/ phones/wallets/sun glasses etc which are hiding in them.
It works well while sailing, but the lines can't be there once the hatch is closed.
Would a photo help?
A photo would be great. I have heard of a similar mounting whose male partners are the studs used to fit through grommets on sail covers. And the bags have the required grommets.
Now, I have to find the bags with the grommets and the male partners.
Thanks for your help.
copasetic
Richard, I'll send some pictures of the bags which are on SMOKE, which may be helpful. Not being a computer wizard I will send them to our wonderful Admin, with a request that he pause from stirring boiling lava with lightning bolts and somehow relay them to you and others who may be interested.
Email
pfranck(at)optonline.net
If you are unable to go through our able admin.copasetic
A photo of the bags is now available in Black Arts, in the Various Projects - On Deck section.
