#1 2007-02-18 21:30:08
Aragorn
Cockpit Table (for Tiller-steered Boat)
   I recently heard from a 27' owner in California who had read about Aragorn's interior re-fit in the "Black Arts Section" and he had picked out, from that description, the comment I had made about a transom-mounted table I use out in the cockpit of my boat.
  I e-mailed him the sketch and the write-up he wanted from me so he could build one of these 3' X 2' tables for his own boat. (I made my table of 1/2" teak plywood and 8 feet 1" X 1 1/2" teak edging).
  Since the work of asembling that information for him has already been done, it would be simple for me to re-send the same information
again, so anyone else who might be interested in making one of these tables can drop me a note.
  Clare Jordan --   Aragorn
#2 2007-02-18 21:57:49
Re: Cockpit Table (for Tiller-steered Boat)
Clare,
Your table sounds great. Is there a way to get the plans added to Black Arts?
#3 2007-02-19 23:44:39
Aragorn
Glad you liked the table idea, Mike. I'll e-mail the stuff to Dave W. and he can decide if it's a "fit" in the Black Arts section.
Clare
#4 2007-02-20 06:36:33
Aragorn
David Weatherston has done his usually efficient job and the cockpit table plan is now in the "Black Arts" section ( along with another idea from Aragorn on putting some hidden volume to work as storage).
Clare Jordan
#5 2007-02-20 22:33:09
Clare and David,
Both projects look great. Thanks for adding them.
#6 2007-02-26 05:48:07
Have you ever heard of anyone trying the seat back storage project in a Mk V?
Barry  Oasis, 1987 Mk V
#7 2007-02-26 06:06:08
Aragorn
No, I haven't heard of a Mk V with a built-in bar, Barry, and not being familiar with the configuration of the settees in the Mk V, I wouldn't know what to recommend to you. Some careful measuring might tell you just how much space is available and whether it would be worth exploiting. Also, I don't have any idea what internal (hidden) braces you might encounter either-- ( I only discovered the vertical plywood "brace" that I encountered AFTER I started cutting into the seatback. At that point, I almost gave up on the idea of the bar but I decided to work around the obstacle).
  Clare
#8 2007-02-26 07:10:57
Thanks.  I will check it out this spring.  The backing behind the settees is fiberglass.  I believe it is just part of the liner and that it is not structural. However, one doesn't want to make a mess because that would make it a lot harder to repair than wood backing should the need arise.
Barry
