I recently heard from a 27' owner in California who had read about Aragorn's interior re-fit in the "Black Arts Section" and he had picked out, from that description, the comment I had made about a transom-mounted table I use out in the cockpit of my boat.
I e-mailed him the sketch and the write-up he wanted from me so he could build one of these 3' X 2' tables for his own boat. (I made my table of 1/2" teak plywood and 8 feet 1" X 1 1/2" teak edging).
Since the work of asembling that information for him has already been done, it would be simple for me to re-send the same information
again, so anyone else who might be interested in making one of these tables can drop me a note.
Clare Jordan -- Aragorn
<U>SAIL FOR SALE </U>_
Clare,
Your table sounds great. Is there a way to get the plans added to Black Arts?
Glad you liked the table idea, Mike. I'll e-mail the stuff to Dave W. and he can decide if it's a "fit" in the Black Arts section.
Clare
David Weatherston has done his usually efficient job and the cockpit table plan is now in the "Black Arts" section ( along with another idea from Aragorn on putting some hidden volume to work as storage).
Clare Jordan
Clare and David,
Both projects look great. Thanks for adding them.
Have you ever heard of anyone trying the seat back storage project in a Mk V?
Barry Oasis, 1987 Mk V
No, I haven't heard of a Mk V with a built-in bar, Barry, and not being familiar with the configuration of the settees in the Mk V, I wouldn't know what to recommend to you. Some careful measuring might tell you just how much space is available and whether it would be worth exploiting. Also, I don't have any idea what internal (hidden) braces you might encounter either-- ( I only discovered the vertical plywood "brace" that I encountered AFTER I started cutting into the seatback. At that point, I almost gave up on the idea of the bar but I decided to work around the obstacle).
Clare
Thanks. I will check it out this spring. The backing behind the settees is fiberglass. I believe it is just part of the liner and that it is not structural. However, one doesn't want to make a mess because that would make it a lot harder to repair than wood backing should the need arise.
Barry
