#1 2006-11-06 04:14:11
Cooling system and removal of impeller
na"></SPAN>
na">My Atomic 4 started to overheat this summer, but I did not get around checking the cause until I had the boat on the hard this last weekend.</SPAN>
na">I discovered that the thermostat was closed and rust had accumulated on the platform below. I cleaned out the platform and poured in some antifreeze, initially draining it through the drain plug until the antifreeze appeared pure and then by running the engine for a short time. </SPAN>
na"></SPAN>na">I also discovered that the impeller was only operating with two fins rather then four. I found the material of one of the fins in the housing but not the other one.</SPAN>
na">I have two questions; I have read about an “acid flush” should I do this to remove any rust etc. that may be left in the cooling system and how is it done?</SPAN>
na">Second question; how do I remove the impeller? It appears to be pressure fitted, but when I try to pull it off, part of the shaft slides out. I am afraid to pull harder not knowing how the shaft is connected in the gear housing.</SPAN>
na"></SPAN>na">I appreciate any comments and advice.</SPAN>
na"></SPAN>na">heinz</SPAN>
#2 2006-11-06 05:27:05
Re: Cooling system and removal of impeller
Do yourself a big favor, go on line to <A href="http://www.moyermarine.com">www.moyermarine.com</A>.... buy the book that he sells and also go into the guest log etc.... all your questions about the A 4 can be answered there...if not , call Don Moyer himself, a very nice gentleman that is Mr. Atomic 4
It is a great little engine, just take care of it.
"IRIS"
1975 C&C 27 MKlll
Hull NO 453
#3 2006-11-06 06:00:26
Thanks very much for your quick response. I will check it out immediately.
cheers
heinz
#4 2006-11-06 20:36:48
c&c27dyc
When you pull the impeller out, don't fret about the shaft - pull it out.  (Taking notice the orientation of the fins) You will then notice how the shaft attaches at the inboard end.  After replacing the impeller reverse the process and turn the shaft the direction the fins were when you removed it and the shaft will find its home.
Don't forget the gasket and do not over torque the screw-bolts.
Dean M Baldwin
Morgan "D"
Mark III - Hull 516
Halifax, N.S.
Dean M Baldwin
Morgan "D"
Mark III - Hull 516
North Sydney, N.S.
#5 2006-11-08 03:06:46
Thanks Dean, I also found a picture of the shaft at Moyer's. It shows the shaft having a fork like slot at the gear end. As you suggested, I will mark the shaft somehow to help with the alignment afterwards.
cheers
heinz
