#1 2010-01-19 05:38:32
skiffink1
Replacement for Marmac Engine Controls
I am trying to find a suitable replacement for the Marmac Engine Controls.  Has anyone replaced these controls and if so, what did they use?  Engine is a Yanmar 1GM10.  Thanks
Keith Skiffington
Keiro
C&C 27 Mark V
Keith Skiffington
Keiro
C&C 27 Mark V
#2 2010-07-16 14:46:17
Re: Replacement for Marmac Engine Controls
Looks like someone has had success with replacing with a Morse MV-2  (later version is the MV-3).
http://www.westsail.org/discus/messages/11/1300.html?1204908565
My transmission cable end snapped, due to the engine control handles spinning too far around.  I need a better solution and the morse may be the answer http://www.correctcraftfan.com/Downloads/Morse_MV-2_Owner_Manual.pdf
No more holding one lever while moving the other?!   I wonder if the cable will fit.  I hope not to have to replace both cables and the control.
Any experience out there?
Tim Quinton
Dark'n'Stormy
Sail 610
C&C Mk V
#3 2010-07-25 21:18:41
For the record, the correct replacement cable for my shifter on a Mk V with Yanmar 1GM is a Teleflex 3300 model CC172 or (newer part number) CC230
