#1 2021-11-20 16:32:47
brianb
mast step repair
hi folks my 1978 mkiii had a concave around the mast step when i purchased it. i have removed the skin and damaged core and found there was plywood sandwiched between the upper and lower skin under the stainless mast step. has anyone done this repair and your recommendation to replace core with new ply balsa or straight glass with a stainless support sandwiched.
thanks for any and all input.
boat was out of Goderich ontario name is no shame hull #727 thks
1978 c&c 27 mkiii h#726
port stanley Ontario
#2 2022-01-13 15:23:15
ibanezplayer
Re: mast step repair
The boats all had a marine ply base in there, should try to replace like-for-like. It's lasted 40 years, so you won't have to worry about it again smile
