My transmission does not engage in forward or rear. The transmission shifter works and moves clearly forward and aft. I heard a noise and it sounded like a massive slip or breakage. I need to access the transmission box, but does anyone have tips or suggestions? Does anyone have experience replacing the transmission without hauling out the engine (as I am able to pick up a cheap replacement in our club)? I know what the transmission access plate looks like and I understand the operation of the forward 3 finger teeth versus the reverse drum actuation. The fact that it works in neither direction does not bode well?
Several A4's I witnessed never really clicked into reverse and the skipper held the shifter back with his foot or hand and a whirl noise was heard.
Also, one time a skipper had the same phenomenon going forward and a sharp eye discovered that the raw water intake hose was interfering with the big shifter lever down in the engine compartment.
Good Luck
Thanks that gives me something to troubleshoot.
I suggest you search and post over on Moyermarine.com There is a sub-forum dedicated to the reversing gear ... Also grab a copy of their Atomic 4 manual and there is a reversing gear video that you can purchase.
Cygnet
North Saanich, BC
Cygnet
North Saanich, BC
