#1 2011-05-22 02:11:51
kas
Need Help: Looking for an experienced A4 mechanic
Hey Everyone,
I'm in need of a reputable A4 mechanic.  I'm located in Oakville.  Any recommendations?
I've been struggling as of recently with my A4.  I've purchase several new components for the aging engine, specifically a new dual action thermostat, housing, spacer from Moyer Marine.  In my attempts to install the assembly I found that the housing stud threads were stripped.  I tried to remove one of the studs and unfortunately broke it in the process with about 1/8" of the stud remaining above the head.
Any help would be greatly appreciated.
Pete
#2 2011-05-23 00:46:18
Re: Need Help: Looking for an experienced A4 mechanic
James Khudoo was head mechanic at RCYC for 20 years. As a Port Credit-based independent, he did a marvellous job at getting my A4 running, along with its associated electrics. www.jlcmarine.com.
#3 2011-05-23 10:36:50
CJ21
hey there.... try Scott Strang at G&B sportmarine @ bronte harbour. great guy and knows them inside and out.
Christine
Silver Fox
Mark II, Hull 417.
