I have just hauled the boat and noticed a crack in the glass starting at the trailing edge of the keel where it joins the hull. torqued keel bolts and tried water again, now no problem.
EDITED Post:
My reply doesn't make a lot of sense without seeing the original question that was posted!
Anyhow my point (below) is that:
- Visible horizontal seam between lead and fibreglass is fairly normal, although many boats don't show it very much.
- There always seems to be a little (I mean a little) movement between the two -- this is what produces the horizontal seam. There should never be "play" or actual noticeable movement or flexing.
- Keel bolts should be inspected periodically for proper torque as well as damage or corrosion.
- Leaking of water through the keel bolts is not a good thing (either in during the summer or out after lift-out).
- Vertical cracks are not normal, and should be checked carefully and addressed by someone who knows what they are doing -- they could be signs of a hard grounding and structural damage.
My original post follows:
[It's at the aft end of the keel, up in the glass (i.e., in the bilge area)? Sounds very much from those few words like the boat has been run aground hard, especially if its weeping water through the crack.
This is a significant repair (that wasn't done properly the first time). If you are handy with epoxy then you know what to do -- if you're not sure, then you should consult professional help (marine surveyor, reputable repair yard, and maybe your insurance company).
No amount of play in the lead keel is acceptable!
This is significant damage that should be addressed before you put the boat back in the water -- but it's fixable.
(I'm assuming the worst based on very few words, but until you know more about it, I wouldn't take any chances.)
Keep us informed -- post pictures, and remind us where you are laid-up - maybe people can provide reputable referrals for help.]
end of original post
Chuck
Chuck Lanning
NSC, Ottawa
Chuck Lanning
NSC, Ottawa
