Hi - I have purchaed a C&C 27 with a reconditioned engine that needs installing. I need good pics of the wiring harness / electrical connections on the Yanmar 1GM10.
If your boat is in Toronto, perhaps I could view in person.
Thanks.
Reply here, or via email at tim at electricvillages .com
Tim
C&C 27 Mk V
Mofongo
The wiring is quite simple and is in the shop manual Should be on the net somewhere also. Only about 6 or 7 wires . Ground plus battery plus 1 for starter solenoid ,1 or 2 for alternator plus tach,oil press and temp.Others in the harness are for saildrive seal failure
<img style="float: left; border: 0; margin: 10px;" src="http://www.electricvillages.com/images/MofoBits.jpg" alt="Yanmar 1GM10 Wiring" width="320" height="400" />
Is this the connection for the saildrive? (I don't have a saildrive, so I hope I don't need it since I can't figure out where it goes.)
You can look at mine at EYC
jim
jwenteATrogers.com
replace the AT with @
