#1 2006-07-14 00:41:34
cneufeld
Stantion Bases
I've seen at least two different rail-mounted stantion bases in the Black Arts section.  Does anyone have information regarding where these might be obtained?  They certainly appear to be a better alternative than those I have mounted on my MK I.
Also, I'd like information on alternative handrail arrangements.  Any advice from those of you that may have made changes?
chuck
#2 2006-07-14 01:50:39
Re: Stantion Bases
Try South Shore Yachts, they are listed in the contacts section of the web site. I would suggest you call them rather than email, they respond quickly to phone calls but tens to be slow in returning email contacts. You will likely find that they stock all of the different stantion bases that C&C used over the yrears.
Still Knot Working Mk5 Sail #75
#3 2006-07-14 10:51:34
Re: Stantion Bases
Thank you, Steve.  Any thoughts regarding handrails?
chuck
#4 2006-07-16 00:08:10
Re: Stantion Bases
HMP in Toronto (Holland Marine Products) carries several styles of rail mounted stantion bases for C&C
