To each his or her own, but for several reasons I dislike instruments mounted on the cockpit bulkhead. That leaves me the option of a pedestal mount or, my preference, atop the FRP moulding that covers my Mark III's companionway slide. Anyone else gone this route? If so, can you recommend a triple-display housing (Raymarine ST60s) that would do the job and where you purchased it or had it made? Any recommendations on cable routing? Thanks in advance.
Santiva
Hello Ken
I carried out this project on my Trapper 500, I used an instrument pod from Scanstut which was designed for a binacle, I had two short s/s mountings made up and bolted them to the hatch garage then fixed the pod to them. The worst bit was the wiring, I used a gland on the coach roof near the mast to pass the wind instument cable through and fed the log and sounder cable in conduit up the bulkhead next to the mast post, I then fed them between the headlining and deck to a point below the hatch garage and then back through the deck, a cow of a job but worth the effort.
I have some pictures if would like to see the finished job.
Brad Croshaw
Hi Brad. I'd appreciate seeing the pix if it's not too much trouble. Thanks.
Santiva
OK,
where do I send them?
Brad
if electronic, <A href="mailto:ken.pole@sympatico.ca">ken.pole@sympatico.ca</A>
if the other option, Ken Pole, 1950 Highridge Avenue, Ottawa, Ontario, Canada K1H 5H3. I'll cover costs of printing, postage, etc. with something.
Santiva
emailed
Brad
Ken,
I have been kicking around the idea of eventually doing the same on my 27. I have yet to buy the electronics but probably will next year. Can you forward me the pics too. Maybe when this deep freeze is over I could drop over and have a look at your setup?
Larry Graham
Oriana
RYC Ottawa
<A href="mailto:rblade@rogers.com">rblade@rogers.com</A>
