#1 2022-06-24 10:25:22
CC27RedSurge
Mast Part
I have now owned a lovely '79 MKIII  for a year and am slowly getting things that were neglected back up to standard. My request is, What is the proper name of the piece in the mast that keeps the main sail hanks in the slide and keeps the goose neck down?  And then where would be the best place to get one?
Thank in advance for any help
Art
#2 2022-06-24 12:01:23
pablorusjan
Re: Mast Part
Hello,
I do not know the name, but the description is clear enough. Give a phone call to Klacko; https://www.klackospars.com/
Regards
Pablo
S/V Mystic
MkV #138
#3 2022-06-27 00:02:15
brianb
Re: Mast Part
it is a sail slug stopper! any online or brick and mortar marina will have or can get them.
that said a lot of the c&c 27's I've seen just have a 3/8 thick piece of bakalite with a screw through it. you loosen the screw and turn to open or close.
the gooseneck may have a small piece of aluminum or stainless above and below it, that slides into the track or just between the rails that screws into the mast.
this would be much easier if I could figure how to post pics.
if you leave your email I can send some
1978 c&c 27 mkiii h#726
port stanley Ontario
#4 2022-06-27 08:16:01
foroadmin
Administrator
Re: Mast Part
Hello Brian,
To post a pic, just click "Uploads"  (option more right below) under this "text area" where we write the post and the tags appear automatically.
Regards
Pablo
#5 2022-06-27 21:21:19
brianb
Re: Mast Part
hope this worksmini_IMG_8784.jpg the stop under the gooseneck is the same as the one on top hope this helps. thanks for the instructions pablo
#6 2022-07-09 18:16:09
CC27RedSurge
Re: Mast Part
Thanks Everyone
#7 2022-07-11 14:31:37
Superior Blue
Re: Mast Part
RedSurge - the baklite fitting was also missing on our boat, and I purchases an aftermarket slide stop with a thumb screw that held it in place.  But the downward pressure of the sail slide when the sail was furled caused the slide to slip out and lost overboard.  More than once.
I then used a pencil rubbing to trace the gap in the mast sail slide, including the exact location of the threaded screw.  Cut several plastic sail slide stops out of a plastic sheet, and drilled the hole for the screw.  No problems since then.  Still need a screwdriver to remove the sail slide stop, but at least the stops are going overboard.
Phil Peterson
Superior Blue
1973 C&C 27 Mk II
Bayfield, WI
