#1 2013-07-02 04:45:14
sociopath
Mark V Outhaul
I need to change my outline.. Before I go rippin things apart and trying to pull a line thru.. can anybody tell me what's in there? Is there any purchase? I probably have just a stock set up with modifications..
Kerry Marsh
Charlottetown Yacht Club
C&C 27 Mark V - Sociopath
kmarsh@upei.ca
Kerry Marsh
kmarsh@upei.ca
#2 2013-07-02 13:48:59
Re: Mark V Outhaul
Kerry there is no purchase inside the boom so just use the old line to pull in a messanger line and then use that to pull in the new outhaul line.
Still Knot Working
Mk V #75
#3 2013-07-13 23:39:06
sociopath
Re: Mark V Outhaul
Thanks Steve.. Removed the old 1/2'' line and replaced with 7 mm spectra,  a small block and jam cleat.. 1 less line to worry about on the cabin top..
Kerry Marsh
kmarsh@upei.ca
Kerry Marsh
kmarsh@upei.ca
