#1 2007-08-28 04:40:17
GBadgley
The Smile?
Ahoy!
I'm presently contemplating the purchase of a Mark V.  Evidently, it has a crack on the keel/hull joint.  I thought this was an issue for other Marks but not the V.  Has someone else seen this on a V?
Also, the boat comes with a double axle trailer with brakes in good shape.  I don't need the trailer.  Does anyone know roughly what it might be worth?
#2 2007-08-28 06:10:01
Re: The Smile?
On a 27 MkV and almost evey other C&C that was made.  Look for a thread by Markus Opitz (CARADIN) on his solution.
P.S. It is only a smile until you have tried to repair it 4 or 5 times.  Then it is a smerk....MURR
