#1 2004-11-24 01:06:58
Oil changes
I just installed Moyer's extended dip stick on the A-4.  Not an easy job due to extremely cramped quarters--as we all know.  It will be close to impossible to extract oil thru the extended tube so I'm thinking of putting Moyer's oil change kit direct to the pan.  Has anyone installed this kit?
TksDave Tinder
DAWN BREAKER  Mk3
Ft Myers
#2 2004-11-24 02:23:32
Re: Oil changes
I thought about that kit, then decided to try getting the oil out via the port under the carb (which is where Mr. Moyer's fitting goes). Works fine. It takes a bit of care getting your fingers on the plug for the last few turns when putting it in or taking it out, but otherwise it's an acceptable solution. Cost: $0.
