#1 2018-08-05 04:38:31
JWente
MK II Prop Shaft for propeller conversion
posted for Eddy
______________________________
Hello there.
I currently own a C&C 27’ MK 2 1974.
I have recently changed the atomic 4 for a yanmar 1 gm.
The original pop doesn’t work for the diesel engine rpm. I’m looking for the specs of the cone end of the 7/8” shaft in order to order a fixed two blade prop.
I havent taken the prop off since im still in the water but until I do that I would like to get the specs that way i can have the new prop ready for when i get hauled to change it.
Could you please give me any information you have or point me in the right direction please. It would be very much appreciated.
Thank you in advance and best regards
Eddy
