#1 2015-06-01 12:05:59
doogymon
Prop Puller
Hi
Any testimonials on what type of puller and techniques?
I have a fixed two blade with 1" shaft.
Can the C-Clamp style do the trick?
Much obliged.
Doog
#2 2015-06-03 03:06:40
Re: Prop Puller
Prop pulling normally only is problematic with some folding props. Almost any puller will do for a 2-blade fixed prop. The C-clamp style with a screw bearing on the centre of the shaft is preferable to the type you hit with a mallet.
I'd double-check that shaft diameter (not that it's particularly relevant to this task); most 27's have a 7/8" shaft.
#3 2015-06-03 04:52:43
doogymon
Re: Prop Puller
Hi David
Thanks very much.
Pretty sure 1" shaft.
Ok so I'll try to beg borrow or buy a C Clamp style.
Would make one if I had the time.
Cheers
Doog
SunnyJ
#827
#4 2016-10-17 03:22:56
doogymon
Re: Prop Puller
David
You were correct.
7/8" Shaft for my Yanmar YSM12.
Also Left Hand screw.
I scored a new Martec MKII (New Old Stock) 1" bore.
There is a company producing bushings to reduce the prop bore size.
http://www.propshopinc.com/Propeller-Bushing-7-8-Shaft-Anchor-Bushings-p19.html
Going to give a go. Hope the Yanmar can spin the 14" folder (9" Pitch).
Cheers
Doog
