I'd like to install a reefing system in our MkIII that can be operated from cockpit. Are there kits available that you have had good experience with? Are there other helpful posts that i have overlooked in this forum?
1981 MkIII, Hull 886
Etobicoke YC, Toronto ON
Steve,
How are you reefing now ? My mark 3 boom came with the blocks on it to run tack lines back to the cockpit via the deck organizer and rope clutch.
http://www.sparcraft.no/single%20line%20reefing%20boom.asp
Gerard Warner
Katara, '79 Mk III
Bronte, ON
Gerard Warner
Katara, '79 Mk III
D.Y.C. Ontario
Thanks Gerard
Your diagram is most useful.
Appears I am missing the pulleys on the boom. Are these internal within the boom? When i get to boat, i will take a closer look to see how they might install.
Steve,
look for me in the yard @ EYC . i'm sanding a F-27 there , i sanded a CS 30 there and have a few other jobs on the go at your club so look for me and i'll take a look at your boom . you should really only need to add a couple of blocks .Maybe loose the Halyard you never use to open a spot in the clutch
Gerard Warner
Katara, '79 Mk III
Bronte, ON
Gerard Warner
Katara, '79 Mk III
D.Y.C. Ontario
OK. Now that temp is above 0, I studied the boom. I see I do have provision for reefing line pulleys at each end of boom. Excuse naive question, but how do I thread reefing line through the boom (PO must have removed). Have thought of a gravity assisted approach where i climb some stairs, put boom vertical and drop line through.
i run mine on the outside of the boom
Gerard Warner
Katara, '79 Mk III
Bronte, ON
Gerard Warner
Katara, '79 Mk III
D.Y.C. Ontario
Thanks Gerard
Perhaps I can do a visit to Bronte this summer and take a look at your set-up.
