#1 2013-09-24 02:32:24
sony2000
Parting out Atomic 4 and assessories
Due to a defective piston, the rest is for sale.
Mechanical gauges, controls as well.
Water pump 202M7 rebuilt.,
Facet gas pump and check valve.
Prestolite distributor. etc.
#2 2013-09-25 08:25:43
malurd
Re: Parting out Atomic 4 and assessories
Hello,
Did the piston damage the head?  Also what is the serial number for the engine?  You can contact me rick.ulam at gmail dot com.  As you can see I changed the email slightly to avoid spam.
Rick
Rick Ulam
Presque Isle, PA
1972 Mk I
Rick Ulam
Presque Isle, PA
1972 Mk I
Idylln
#3 2013-09-26 11:45:45
whippet
Hi
what part of world you live in?   if Toronto, i am in need of starter motor and some other bits.
What do you plan to replace it with?
1981 MkIII, Hull 886
Etobicoke YC, Toronto ON
#4 2013-09-26 13:41:31
sony2000
I'm in Montreal, QC.
The replacement will be an electric motor. The C&C designed P29 has a V-Drive setup, and CB. Because of the CB cable, I've decided not to reinstall an internal combustion engine.
The starter is available.
