hello
I just had my mast re stepped over the weekend on a 1976 markIII. On close inspection I noticed that it was rotated on the mast plate. it is noticeable from head on. I was wondering if it is acceptable or should the rigger have been more careful and is it an easy fix for him. I would appreciate some input
pv
[Please wait a sec after clicking 'Submit'. Our server is not the world's fastest, but if you watch while you click, you'll probably see the button respond, which means your request has been received. "I want action right now" double- and triple-clicking means double and triple postings, which then have to be deleted. Thank you. - Admin]
Peter Vincent
Kirkland, WA
Hi PV.
Now that your shrouds have been tightened, the mast cannot be turned on the step. Your rigger will have to loosen the rig to turn the mast. Before you do that though, take a tape measure and check the horizontal distance from the inside of each upper shroud to the edge of the mast step plate. On my Mk 111 , I found that the plate was not centered between the upper chainplates/shrouds. (Assembled on a Monday??)
To be centered in the rig, my mast has to be almost touching the starboard side of the step. (I now have a "spacer" block for the port side to remind me each Spring.)
With the shrouds, for-stay and back-stay loosened, the mast should then be able to be pried/pushed into the right spot.
Clare Jordan. Aragorn
Clare Jordan,
Stormont Yacht Club,
Long Sault
thanks for the info
its a relief to know that the mast can be rotated without taking it down.
pv
Peter Vincent
Kirkland, WA
