#1 2012-08-13 04:14:24
Gear reduction ratio
Does anyone know the gear reduction ratio for a Yanmar 1GM10 on the C&C 27-V. Has anyone installed a Kiwi feathering prop?
Jerome Tauber
C&C 27 MKV Fast Lane
3 Mile Harbor, East Hampton, NY[/i]
#2 2012-08-14 10:02:58
ALAN FORD
Re: Gear reduction ratio
I looked at the online 1GM manual under item 2. 'specifications', then 'clutch', then 'reduction gear', and it says the following for 'forward and reverse':-
2.21/3.06.    or   2.62/3.06.    or   3.22/3.06
The reverse is constant, but perhaps the forward varies depending on the fitted prop? Someone else may know about your Kiwi feathering prop?
Since we are talking about boats, not cars, and I hate using landlubber language anyway, please read AHEAD instead of forward, and ASTERN instead of reverse, in the above rambling. Thank you.
