#1 2011-04-14 16:00:29
sclaude
Jib and storm jib
In terms of head sails, I currently of a 153% and a 135% that are good.  I also have an old 120% that can be reefed down to a 89% jib.
I am looking a newer 100% and a storm jib, both with hanks.
To comply with PIYA rules the storm jib area must not exceed 5% of I^2.  That is less than 61sqft.
Would anyone recommend dimensions for a 100% jib for a C&C27-2 (luff, leech and foot)?
Stéphane, Sidney BC
#2 2011-05-18 06:48:37
dmartis
Re: Jib and storm jib
Stephane
You can probably use a percentage of your "I" dimension (its around 12 feet) to figure out what size storm sails you need.
That being said, my boat has a 110% working jib that would probably be suitable for winds in the 20-25 knot range.  (I haven't used it much on Lake Ontario)
This sail has a luff length of 30'-3" and an LP of 11'3".
I've also got a storm jib (again, never used, but probably good in the 25+ range).  Luff length 20'2", LP of 6'7"
Hope this helps!
Dan Martis
Dream Catcher
Mark 3, Hull #636
Dan Martis
Dream Catcher
Mark 3, Hull #636
