#1 2011-04-12 11:04:46
cutless bearing
does anyone know the allowable movement of the shaft in the cutless bearing i have 20 thousanths inches up and down and don't know when
i need to replace it can't find anything in manuels
#2 2011-04-12 11:37:24
ALAN FORD
Re: cutless bearing
Gordon, some of the input on "cutless bearings" ( even the spelling is tricky) on previous page 3 of this forum might help you. It is item 10 from the top of that page.
#3 2011-04-13 09:45:00
Re: cutless bearing
thanks the info was really helpful, gordon blimbaum 1975 mkIII "rogue" cleveland ohio
#4 2011-04-13 12:45:15
Re: cutless bearing
This may come across a bit vague, but a very experienced marine mechanic told me that if you feel it's sloppy, you should replace it. I'd translate it to mean that if it moves perceptibly, it's too loose.
