Hi:
If I am flying my 150% genoa, I use the track on the coaming, with the car pretty much all the way forward. This is fime if we're close hauled.  However, when bearing off onto a reach, we now should be using the more forward car on the "regular" track alongside the deckhouse, but I don't know an easy way to transfer the sheet between cars.
If you've experienced this problem, do you have a fix?
Regards,
FLYING CIRCUS #581
San Diego
One of the standard tricks on the Mks I to III for white-sail reaching is to carry a second sheet running under the lifelines and through a block well forward on the toe-rail. On the end of the sheet is a snap-shackle or sometimes just a cunningham hook. As the inboard (close-hauled) sheet is eased, someone reaches over and attaches the new outboard (reaching) sheet. The load is transferred and away you go.
Towser- is the reverse just as easy? disconnecting the snap shackle or hook under pressure while sheeting in?copasetic
Yes, it's easy because while hand-holding the reaching sheet, you've transferred the load back to the inboard sheet (obviously you don't do any of this - nor in all probability is it necessary - if the wind strength is beyond the ability of the crew to do this exchange smoothly). As the inboard sheet comes in for a beat to weather, the outboard sheet goes slack and is easy to remove then hook somewhere where it's not going to cause problems.
that's what we do on Distant Thunder
jim
Further to that tip. We found, on the MkII's anyway, that if you sent the genoa trimmer forward of the the mast while reaching or running the transom lifted out of the water and the boat went much faster. The new sheet lead position is critical and should be set so, when sheeting in , all the ticklers break at the same time.
