#1 2004-06-26 22:59:25
wjames
muffler
"Sesiya" is my boat, bought new in 1976, sail out of N. Georgian Bay.
Had to replace the water pump impellor the other day, but the engine cut out and we eventually found the muffler tank had an inch of crud (bits of rust?) blocking the flow. Now I feel that I ought to replace the muffler tank, and am looking for sources and advice please. Please copy your advice to Bill James (address removed) Thanks a lot.Bill
Please address your responses to the Forum – that way we all learn, which is the point of having a Forum. Bill has logged in and so will receive an automated notice that your reply has been posted. Thank you.
—Admin
Bill
Sesiya, #643 1975
#2 2004-06-28 01:56:22
Re: muffler
I am going to take a guess and say that your boat has an Atomic 4 engine... when my original aqualift muffler went ( rusted through from salt water ) I replaced with a fiberglass one... these are available through West Marine (either store or online) or through your local chandlery... they do not cost much, easy install, and no rust inside or out.
Just match the size to your engine HP range.....
1975 C&C 27 Mklll
Hull # 750453
