#1 2008-11-06 03:20:09
foroadmin
Administrator
Mk V Stanchion base re-bedding
any insights on the markV plastic stanchion base? it looks like the
inboard screws are through the deck. should they be re-bedded?
copasetic
[Moved from a discussion about Mk I-IV boats. It's not a good idea to try to shift a topic from the earlier boats to the Mk V (or vice versa). If the topic has already seen a few posts, the people with the knowledge to answer your question, the Mk V owners, will know the topic isn't about their boats and they'll have stopped reading additions, so you get ignored. Start a new topic and label it to foreground the distinction. - Admin]
#2 2008-11-06 03:26:59
Re: Mk V Stanchion base re-bedding
Yes, you are correct.  the Inboard bolts are through the deck and come inside the cabin.  YES they do need to be bedded.  The two out-board bolts go through the rail. They too are tricky to access because of the rubber rail going around the boat.
CRouse - Gemini, Mark V
#3 2008-11-06 10:19:07
JWente
the good news is that the inner bolt holes are in solid glass.  No chance of balsa rot.
So, as far as I am concerened - if they don't leak, don't bother.
Jim Wente
Distant Thunder
#4 2008-11-07 07:27:31
Good to hear they go into solid glass and rot is not a problem.  If one were to rebbed the inboard bolts, how would one get at them under the liner?
Barry  Oasis 1987 Mk V
