#1 2007-03-13 13:06:02
shaft diameter , mkll
I am contemplating a Martec folding prop for my Mkll,  I find the shaft to be 7/8" they suggest 12x6x7/8.  Any of you folks who say different on the diameter?      R. Meyer.
#2 2007-03-14 00:43:21
Re: shaft diameter , mkll
Shaft from my A-4 is 7/8.
#3 2007-03-14 05:10:01
I have a 7/8 shaft on my MKlll, with an Atomic 4 engine I use an 11 x 5 Martac folding Prop...it allows the engine, when crusing along to run at a better (slightly higher) rpm range.  I know another boat owner with an Atomic 4 engine and he changed to the 5 pitch and is very happy with it.
The C&C27 is a light boat and you do not need a lot to push it.
"IRIS"
1975 C&C 27 MKlll
Hull # 453
#4 2007-03-20 13:42:11
woodenr
Hello,
I have a Mk III with the direct drive Atomic 4.  I had the original (as best I can tell) prop, a folding michigan blue dot 12X5.  The builders file shows that there was a 12X5 folding prop instead of the standard when built.  I always thought that this prop was a bit large, as the A4 seemed to "lug", unable to come up to decent RPMs (no tachometer, but I've spent a lot of time around old gas engines).  I have a factory rebuilt Martec 11X5 ready to go on, we'll see how it goes.
Just one opinion.
Bob Wooden - Rhapsody in Wisconsin
[As I noted in "List of Props", I've added a table of boats, engines and props to Black Arts. I'd appreciate it if all of you could follow up after you've got a bit of running time in and let us all know how the new props work out. - Admin]
