#1 2005-04-12 06:59:16
PHRF-LO C&C 27 MkV
I don't have a PHRF # for my MkV - does anyone know what they rate. Mine is pretty much stock.
Also, how difficult/expensive is it to get measured?
#2 2005-04-12 11:02:42
Re: PHRF-LO C&C 27 MkV
Generally there is no cost to be measured, but a cost for the certificate which varies from area to area. Where are you and what Club do you sail out of ?
Larry Bayer-"Yogi Bear"
#3 2005-04-12 11:20:02
Assuming a standard boat (not shoal draft) with a 153% Genny and a standard spinnaker - 192 whitesail / 174 spinnaker.  If you have a 163% genny subtract 3 to make it 189 / 171.
Jim W
Distant Thunder
Hull #69
