#1 2003-05-20 23:50:46
Head Plumbing
Having just replaced my head I find that I can't get a good seal on the outlet side hose that goes to the holding tank.  This hose travels under the sink and then disappears up under the port side somewhere.  Where does it go? Can it be replaced without removal of all the cabnets etc. in the head?  I'm not sure I even know the location of the holding tank?
#2 2003-05-21 02:19:40
Re: Head Plumbing
On my 27, the holding tank is under the V-berth and I expect that's true of your boat as well. Remove the cushions and have a look.
If you had to replace the head, your hoses are probably rather aged as well.  The good news is that the new hose (at least, the white Australian hose that most Cdn chandleries are now selling) is much more stink-proof. The bad news is that sanitary hose is expensive. Other (less) bad news is that it's a bitch to bend through the convoluted path in a 27. I used a heat gun (very gingerly) to soften it up.
"Towser"
#3 2003-05-21 08:35:35
Re: Head Plumbing
David, If your holding tank is in the V-berth, then where is your freshwater tank?  Our Freshwater tank is in the v-berth and the holding tank is in the cabinet behind the head.  My boat is older than your though.  FYI.
1973 C&C 27 "Goldrush", Chicago IL
#4 2003-06-06 09:12:57
Re: Head Plumbing
The holding tank and the freshwater tank are both under the V-berth (don't want to confuse those hoses!).
"Towser"
#5 2003-08-29 01:25:22
Re: Head Plumbing
Hi Chris,
While this is not too timely maybe some other people might benefit from it.  Behind the panel you might find there is a clamp holding the hose to the V berth bulkhead. If this is the case the hose will not pull through and you will have to remove the panel covering the tank. If the clamp is loose or missing you can pull straight down and remove the hose without removing the panel. See my post on replacing te holding tank to learn how to remove the panel.
John
C&C 27 MKIII 1976
