#1 2023-05-21 11:35:08
Tim Finn
Shifter cable
I'm looking for a shifter cable for my 1983 Mark 3. Pedestal steering. The id # on the cable is"CC19057 teleflex 6303". Does anyone know where I can find one?
#2 2023-05-21 11:36:51
Tim Finn
Re: Shifter cable
My 27 Mark 3 is a 1980 not 1983 as I previously posted
#3 2023-05-25 10:13:25
jaghtschip
Re: Shifter cable
Hi Tim,
I'm sure someone is more knowledgeable than I - but if I am not mistaken, most engine control cables are universal. You may need to specify a specific terminal fitting. The terminals are likely specific to your engine/pedestal setup and less about boat model/year.
You could start here:
https://www.fisheriessupply.com/telefle … s/ccx63305
Perhaps someone in a parts department may be able to give you better advice specific to your setup.
Hope this helps.
EDUAM
MkV 564
RYC, NJ
#4 2023-06-11 08:18:05
Tim Finn
Re: Shifter cable
Hi jaghtschip,
Thanks for the reply. I did manage to free up the existing cable. It is installed and working fine. I do appreciate the info and once again, thanks.
