Hello C&C'ers
I am looking for my C&C 27 MK V structure, is it steel and foam ? solid wood ?
Thanks for your help
Marc DuboisMarc Dubois
C&C 27 MK V 1988 hull 152
Marina d'Oka
Oka, Quebec
www.SailÀVie.ca
Marc Dubois (SV Geronimo)
Oka, Quebec
Www.YachtingZone.ca
Hi
It is a Fiberglass outer shell - the join is at the leading edge of the rudder
Top part out of the water is painted white over the fiberglass
I believe the interior is foam
I confirm it is all foam, got a new one and before that I has to fix the old one, it was all foam
Oka, Quebec
Www.YachtingZone.ca
Interesting -- (resurrecting an old thread here)
We had a crack on the aft face of the upper part of the rudder, along the centre. I thought it might be stress crack so I shaved the gelcoat off of that face. Turned out that the top part of our rudder is laminated marine ply; it was not a stress crack, and I had to fix it then. I would guess that the interior of the blade is also (mostly) plywood as well.
Cheers
Chuck Lanning
NSC, Ottawa
