#1 2016-12-23 04:22:26
mikeware
Prop puller
Now that I have read the Black Arts and realize I do not need to be frustrated by a boat that won't backup (straight) or stop reliably, I have decided to spring for the Indigo 3 blade prop. Anyone in the Toronto area have a prop puller I could borrow? Or is there any chance a rubber hammer would be successful on an original 71 installation? Or any chance someone has a prop for sale for some reason?
Mike Ware
C&C 27 Mark 1 1971 Parsifal
Bronte Harbour Marina
Mike Ware
#2 2016-12-24 03:24:10
Jeff
Re: Prop puller
Sorry I don't have a puller, but I will advise not to use the hammer. Did that on mine and ended up with an alignment issue. Just curious too, what is your hull number?
Jeff
C&C 27 Mk I #4
Clockwork
Port Stanley, On.
C&C 27 Mk I #4
Clockwork
Port Stanley, On.
#3 2016-12-24 06:07:22
mikeware
Re: Prop puller
I believe from the nameplate #85
CC278571N
Mike Ware
Mike Ware
#4 2016-12-25 04:15:58
Re: Prop puller
I have another option that will get your desired effect, but that does not involve changing your prop - change the way you handle your throttle.
All props "walk" to one side, particularly in reverse when starting from stationary (a 27 stern swings to port in reverse). The way to avoid this is to get some way on the boat and some flow over the rudder so it is effective in counteracting the swing. (3-blade props have the reputation of being less prone to walk, not because they are inherently less prone to it, but because even at low revs, their far greater blade area and consequent thrust gets the boat moving more quickly and the rudder working more effectively, before the stern starts to walk.)
Instead of putting the engine in gear and easing on the throttle, shift into reverse and give the engine a shot of power; in other words, rather than accelerating from idle to 1,000 rpm, run up to 1,500 or so, but just until the boat begins to move. At that point, drop back to a point midway between 1,500 and idle. That little shot of power will give you enough motion to allow your rudder to bite, and if you give your rudder a touch of starboard helm to counteract residual walk, you'll exit your slip straight as a die.
Do something similar when stopping - rather than easing into reverse, shift and give the engine a good shot of power. That burst of reverse thrust will stop the boat reliably and quickly enough that there is no time for prop-walk.
After I saw someone handling a boat this way, I took out a C&C 34 (with a Martec folder, a worst-case combo)  and practised around a plastic buoy (so I could run into it with impunity). In short order I could put that boat anywhere I wanted. It wasn't difficult - in fact it was fun - and since then, I've had no qualms about putting Towser or any other boat anywhere.
#5 2016-12-28 06:13:07
mikeware
Re: Prop puller
Thanks for the input, David. Sounds interesting and I would love to try. However was planning on getting the new prop and tools organized before Spring launch. Last year a leak during launch caused me an extra $500 for extra in and out so would like to get the drive train done first. I have a mark 1 with the protruding rudder. Not sure if this would affect the maneuverability. Anyways will have to decide.
Mike
Mike Ware
Mike Ware
#6 2016-12-28 06:13:08
mikeware
Re: Prop puller
Mike
Mike Ware
Mike Ware
#7 2016-12-29 13:03:25
doogymon
Re: Prop puller
My boat's stern should walk to starboard in reverse (Left Hand Screw)
but it doesn't. Instead she just goes straight backwards like an
arrow...perhaps because the prop shaft shoots out to port by design.
I can still turn her on a dime in a short space though with fwd and
rev action.
Cheers
Doog
