#1 2015-02-26 13:56:04
mbasscc27
Original stain color for interior of 1972 MKI?
Does anyone know a match to the original stain they used on a 1972 MKI? Is it standard? It appears not to be just oiled, seems more reddish? I am rebuilding the galley and nav station counters and cabinets and need to match the stain. Any help would be appreciated. Thanks Mike.
Mike Bass,
C&C 27 hull 165,
Pend Orielle, Idaho
Mike Bass,
C&C 27 hull 165,
Pend Orielle, Idaho
#2 2015-02-27 04:38:00
Re: Original stain color for interior of 1972 MKI?
I would suggest that after the passage of so much time, the original stain colour will have altered considerably. If I were you, I'd get something that looks close, along with some small tins of colours that will modify your starting colour (maybe a small tin of a red hue plus ebony, to neutrally darken). Mix (recording what you add and in what quantity) until you have something that looks reasonable, then apply some to a test piece of the wood you're using. Let it dry, evaluate and adjust until you're satisfied.
#3 2015-03-02 03:21:40
doogymon
Interested as well.
Nice to be able to touch up like shoe polish.
Staying away from anything varnish-like.
doog
#4 2015-03-02 03:21:41
doogymon
Interested as well.
doog
#5 2015-03-02 05:16:03
mbasscc27
Me too, I tested the engine cover area, scrubbed and lightly sanded it then applied some fresh teak oil, I was so impressed with how it came out I will be doing the entire galley area this spring as I install the new countertops and refrigerated cooler. If I use teak oil or lemon oil I will not have to worry about stain color again.
Mike Bass,
C&C 27 hull 165,
Pend Orielle, Idaho
Mike Bass,
C&C 27 hull 165,
Pend Orielle, Idaho
#6 2015-03-02 05:16:04
mbasscc27
Mike Bass,
C&C 27 hull 165,
Pend Orielle, Idaho
Mike Bass,
C&C 27 hull 165,
Pend Orielle, Idaho
#7 2015-03-08 20:48:14
Katara
I like oil based Gel Stains a little more vertical surface friendly . unless you like runs and drips of liquid stains . Mahogany from Minwax is the closest match in my opinion . Tint is a personal thing , each product has it's own colour chart .
Gerard Warner
Katara, '79 Mk III
D.Y.C.  Ontario
Gerard Warner
Katara, '79 Mk III
D.Y.C.  Ontario
