#1 2014-11-19 12:01:33
doogymon
Folding Prop question
1979 MkIII with YanmarYSM12  (LH Screw @ 1" Shaft Dia)
Eyeballing a Gori folding prop with gears but it seems
like the blades might touch the rudder when folded.
Black Arts doesn't cover off on that combination.
Any solutions or testimonials.
Cheers * Thanks
Doog
#2 2014-11-20 04:26:12
Jeff
Re: Folding Prop question
How big is the prop?
Jeff
C&C 27 Mk I #4
Clockwork
Port Stanley, On.
[Our Forum software is older-generation and does not give good feedback when it's digesting a post. Please give it a minute before clicking 'Submit' a second (or in this case, fourth) time. Duplicate posts are now deleted. - Admin]
C&C 27 Mk I #4
Clockwork
Port Stanley, On.
#3 2014-11-20 04:26:14
Jeff
Jeff
C&C 27 Mk I #4
Clockwork
Port Stanley, On.
C&C 27 Mk I #4
Clockwork
Port Stanley, On.
#4 2014-11-20 04:26:16
Jeff
Jeff
C&C 27 Mk I #4
Clockwork
Port Stanley, On.
C&C 27 Mk I #4
Clockwork
Port Stanley, On.
#5 2014-11-20 04:26:21
Jeff
Jeff
C&C 27 Mk I #4
Clockwork
Port Stanley, On.
C&C 27 Mk I #4
Clockwork
Port Stanley, On.
#6 2014-11-20 09:46:11
doogymon
12"  x 9 with 1 inch shaft is the size of the two blade Gori.
Existing fixed 2 blade is a federal 13" x 8.
http://www.ipernity.com/doc/1125763/35981655
What does the 4 mean in the pic?
If the blades don't touch the rudder, i think the prop will work.
If I need and an inch or two, cut the shaft and re-thread?
Cheers
Doog
#7 2014-11-21 10:19:13
sony2000
Measure the distance from the bottom of the notch in the torpedo section, to the tip of the prop.
Then from the end of the driveshaft add that distance and 1/4'".
Do this with the same slope of the shaft. Does it touch the rudder?
