Go to the following link for a PDF spec sheet you can print with photo's of the boat - http://nw.moore24.org/wordpress/wp-content/uploads/2012/06/Libra-Advert.pdf
C & C 27 MKI
Year: 1972
Current Price: US$ 8,750 obo
Located In The Northeast, USA - Currently Amesbury heading for Portsmouth then Portland Maine by the 14th of July
Hull Material: Fiberglass
Engine/Fuel Type: Single Diesel
<img src="http://nw.moore24.org/wordpress/wp-content/uploads/2012/07/IGP5330.jpg" alt="Libra at anchor" />
Libra is currently on a 4 to 6 month cruise from the Annapolis, Maryland area to points Northeast. My wife, myself and our 85lb Labrador, all from Seattle, are spending the summer exploring the East Coast and found the C&C 27 was the perfect boat for it. Offshore capable with her 2.08 capsize ratio and 4’ 3” keel, she is also small enough to explore almost any inland waterway and with her 18.46 sail area to displacement ratio, she can do it under sail. Libra is proving to be a very capable and comfortable boat for 2 adults and one dog on a 4 to 6 month cruise. She has sailed to weather in 30 knot blows plowing through 4 to 5’ seas like she was born to do it and, she has ghosted across the sounds with her 170% genoa up still moving along at over 5 knots. She is offered for sale at a very competitive price knowing about the many items that have been upgraded on the boat, her pedigree, and the steady working diesel sipping Westerbeke diesel motor. Comparable boats are listed at well over $10,000 throughout the Great Lakes, Canada, and the NE. Her decks have had the non-skid redone (June 2012), many of the items being re-bedded and all is in working order. Her light blue hull has a few scratches from her years of service, but it is nothing a little filler and easy-epoxy couldn’t fix and leave Libra in bristol condition.
Let us know your interest in Libra and we’ll let you know where you can find her or let us know where to deliver her. Libra is available anytime after July/August time frame. We are open to unique offers/trades or ideas/deliveries on this sale.
<img src="http://nw.moore24.org/wordpress/wp-content/uploads/2012/07/IGP4978.jpg" alt="Libra Interior looking forward" />
Additional Specs, Equipment and Information:
Boat Name
Libra
Specs
Keel: Fin
Hull: Blue
Bottom: Black
Deck: White
Dimensions
LOA: 27 ft 4 in
Beam: 9 ft 2 in
LWL: 22 ft 3 in
Minimum Draft: 4 ft 3 in
Displacement: 5180 lbs
Ballast: 2512 lbs
Headroom: 6 ft
Steering: Tiller
Bridge Clearance: 37’
Engines
Engine Brand: Westerbeke Universal
Engine(s) Total Power: 18 HP
Engine Model: M3-20
Engine Type: Inboard
Drive Type: Direct Drive
Propeller: 3 blade propeller
Shaft Seal: Dripless - new 2011
Coolant: Fresh Water
Cruising Speed: 5.5 knots
Maximum Speed: 6.5 knots
Year: 1989
G.P.H.: .25 Gal @ 5 knots, .33 Gal @ 5.5 knots
Engine Hours: Unknown. 1042hrs on broken meter when we purchased the boat - this could also include the original Atomic’s hours. Currently 120 hrs on new meter.
Tanks
Fresh Water Tanks: 32 Gallons built in FRP - cleaned and resealed 2012
Fuel Tanks: 1 @ 12 Gallons
Holding Tanks: 1 @ 6 Gallons
<img src="http://nw.moore24.org/wordpress/wp-content/uploads/2012/07/IGP4972.jpg" alt="Libra Starboard side Galley" />
Accommodations
5 Berths
Marine Head - new 2012
Manual Water @ galley - 2 foot pumps, one for Fresh Water and one for Salt Water
Homestrand Model 206 Pressure Alcohol Stove
Ice Box - with excellent insulation, drains into bilge
Hatch Screens for both companion way and forward Hatch
Description
Starting in the bow is the anchor locker with hawser pipe for rode. Next aft is the forepeak bunk 6’ 3”, plenty of room for two adults. Shelf storage space runs down both sides of the forepeak. The Middle V board is removable and underneath is a partially enclosed boot storage area. The forepeak cushions are original but serviceable. Under the forepeak bunk forward is a good size storage area followed by the 36 gallon FRP water tank followed by the 6 gallon holding tank to port. Starboard under the bunk is open for storage. There is a folding door to close off the forepeak from the Head area.
Following aft after the forward bulkhead, on the starboard side is a very large hanging locker that has soft shelves installed on the forward end leaving plenty of room for hanging items with boot/shoe storage underneath, with a small storage shelf and portlight above. On Port is the Head Sink with both manual and electric water pumps and single round stainless sink. Ample storage compartments are behind the head and under the sink within the cabinet with a portlight above. Next back is the manual Jabsco marine head, new 2012, followed by the main bulkhead and sliding door to close off the head from the Salon.
Aft of the main bulkhead to starboard is the long salon bunk running fore and aft with a large storage shelf behind the seat back. Ample storage is under this bunk with the center storage area being molded into the seat to keep items from resting against the hull and possibly in bilge water. There is a lee cloth under the bunk that connects to the handrails on the cabin top. Headroom is 6’ 2” in this area. To Port is the Dinette table that drops down easily into a double bunk. There is storage under both seats and a storage shelf along the wall under the deck. The Salon cushions have been replaced and are a royal blue color.
Next aft, behind two half bulkheads, to Starboard is the Galley Stove with new counter tops replaced 2012. 2 burner stove up front with ample dish storage behind, drawer under stove with large cabinet storage below the drawer. Then looking aft across the back of the cabin is the Stainless Rectangular sink with foot pump fresh and salt water with DC panel behind sink. Centered on the companion way is shelf space with Stereo, VHF, Fire Extinguisher and Battery switch mounted along this area. To Port is the large well insulated top loading icebox with sliding bin. Outboard of the icebox is a large dry storage area. Along aft wall is the new, 2012, Bluesea shore power breaker panel.
Interior manual bilge pump is located under the starboard bunk aft, accessed from in the salon. Exterior manual bilge pump is located in the cockpit floor. The cockpit has ample storage under both seats w/ motor under companionway and fuel tank out of the way on the forward edge of the starboard lazerette.
<img src="http://nw.moore24.org/wordpress/wp-content/uploads/2012/07/IGP4970.jpg" alt="Libra Port Side Cooler" />
Electronics
Depthsounder - Hawk Eye
DUAL XR4110 MP3/USB/FM Radio Player
Compass
Standard Horizon/25 VHF w/ Masthead antenna
Sails
Battened mainsail - Haarstick, 2 reef points - Good
Genoa - Murphy & Nye - 170%, Hanks, Good
Genoa - Murphy & Nye - 150%, Hanks, Good
Genoa - Murphy & Nye - 130%, Hanks, Good
Genoa - Murphy & Nye - 75%, Hanks, Good
Spinnaker - Murphy & Nye 3/4 Oz. Radial Head - OK
- all sails old dacron but stitching is great and not rotting or soiled, very serviceable cruising sails
Rigging
Tiller
Spinnaker pole
Attachments for Runner’s and Cutter/Baby Stay
Whisker Pole
Boat Hook
Inside Equipment
2 Manual bilge pumps
Marine head - new 2012
Y-Valve
Head Thru Hulls, both New 2012
Electrical Shore Power Equipment
Shore power inlet, 30 amp Smart Plug - new 2012
50’ SmartPlug Shore Power Cord - new 2012
Blue Sea Systems 120v/60hz AC distribution panel with reverse polarity breaker and one 20amp circuit connected to 2 outlets. One outlet is for the battery charger, one outlet is for the salon accessories - all new 2012
ProSport 12 Automatic Battery Charger - new 2012
Electrical 12V
1 12v 190 amp hour Lead Acid House Battery
1 12v AGM Starting Battery
Smart AC 400W Inverter with USB
4 position Battery Switch
DC Breaker panels
VHF
Stereo w/ interior and cockpit speakers
Depth
Ben Braden
C&C 27 #139 Libra
Somewhere in the NorthEast USA
Ben Braden
C&C 27 #139 Libra
