My project C&C needs a MAINSAIL that is either in Kevlar or Mylar and in good condition. Please let me know what you have.
Hi. With respect, you might want to recheck that. There is a Wave 26 about 2 or 3 slips from my 27 Mk V, and there are several older 27's in the marina too, tho I don't know the Mk's. The Wave has same hull as a Mk V, but a very small rig. Its mast has to be at least 3 feet shorter than my Mk V rig.
Good luck.
Barry, Oasis, 1987 Mk V, no 575
Barry, My I is 35.3 ft. from the chart. Having checked the rig dimensions for the two that I mentioned, they both are listed with an I = 35.5 ft. The Mark V is not listed.
From the Association site I best match the Mark 11.
...Scott
The sail manufacturing site has mislead me on the I an J lengths. From another source of boat specifications, I should use an I of 37.25 ft. and a J of 11.63 ft.
Therefore the 27 Assoc. chart would match me to a Mark 111 and a Mark 1V, but not a Mark V.
Hi. If you check the C&C site, you will find copies brochures for both the 26 Wave - it lists bridge clearance as 34`6``. For the 27 Mk V it lists the I measurement as 35`5``.
Hope this helps.
Barry
Bump!
