#1 2003-07-11 01:18:48
Edson Steering
First - thanks everyone for help already offered on this forum.
Second - my question.... I have a MkIII with Edson Steering (model S-613).  It has the typical pedistal with two separate stainless tubes aft of it that serve as cable passage ways for the clutch and thottle cables.  The clutch lever is easily removed when not in use.  The casting that the clutch lever "plugs" into has cracked and is in need of replacement. Unfortunatly this is a discontinued part and Edson no longer stocks them.  Does anyone have a good suggestion for a fix or replacement?
Thanks Chris
#2 2003-07-14 00:39:19
Re: Edson Steering
I wonder if it wouldn't hurt to give South Shore Yachts a call see if they have any extra wheel parts. At the end of the 27 run almost all boats came with wheel steering. The bought all the extra leftover parts.
