#1 2011-08-09 01:21:19
Tonyj
Foot pump for galley sink
Hi:
I'm not a fan of the flipper pump on the galley sink on my MkV.  I'd like to replace it with a foot pump, but fitting one looks tricky.  Has anyone done this?
Regards,
Tony Jeske
FLYING CIRCUS #581
San Diego
#2 2011-08-09 06:18:49
bosco
Re: Foot pump for galley sink
Hi Tony.
  As a suggestion, try an electric pump which may be much easier to rig up. I cannot recall now but I beleieve I bought mine at an RV dealership (cheaper than a marina). It came with a 12 volt pump and a tap mounted on a base which had a switch for the pump. I later changed the switch to a push-button (so it couln't be left on.)
Clare Jordan
Aragorn
Clare Jordan,
Stormont Yacht Club,
Long Sault
#3 2011-08-09 07:58:32
Installed a foot pump last year in the galley area and an electric one for the head sink. Foot pump installation was a no-brainer; I drilled a hole for the pedal and then screwed the pump onto a small plywood plaform screwed to the inside of the locker. Can send some pix later in the week.
#4 2011-09-23 07:53:06
Following up on my earlier response, you didn't indicate whether you wanted pix. Maybe I wasn't clear enough. Let me know. Cheers.
#5 2011-09-24 01:06:23
Tonyj
Hi Ken:
I won't need a photo.  Your description was enough to show me how it's done.
Tony
MkV #581
FLYING CIRCUS
San Diego
