#1 2004-07-22 00:10:48
Engine Control Panel Pull Knobs?
I just bought a 1979 C&C 27 Mk III.  The plastic pull knobs on the ignition switch and on the bilge blower switch are cracked and broken.  I have been trying several sources to find where I can buy some new ones  without any success.  Does anyone know where I can find these elusive little knobs?  I live in the Toronto area, and would prefer to get them locally, but if need be, I will order them in from out of town.  Thanks in advance for any tips!
#2 2004-07-22 00:32:49
Re: Engine Control Panel Pull Knobs?
Last person that asked me this question was able to find them at Canadian Tire in the Automotive section.
#3 2004-07-22 02:09:38
You may not be able to find the exact copies of those knobs, but if you think a little creatively you might be able to find knobs in places like radio shack, home depot, etc.... in different colours..... it has been a while but the ones I found the holes were a different size from the original, thus some thickened epoxy and a little bit of tape fixed that issue..... for me red is the ignition, blue the blower, green the choke...... I think you get the picture
"IRIS"
1975 C&C 27 MKlll
Hull # 27-453
#4 2004-07-26 05:32:44
Check to see if you have a "Cole Hersee" Distributor in your area. They have two different replacement knobs in their catalogue.  Part Number's  M-8113-10 and M-8197-10.
Regards
Ralph Ainslie
Hyperion
