#1 2008-05-16 08:59:21
capricous
Gauge replacement
Who makes and or supplies the gauges, specificaly the fuel,for the C&C? Couldnt find it in old posts,but thats probably me.
Thanks in advance
Dana @ Marblehead Ma
Capricous Hull #599
Capricious Mark 3 Hull #599
#2 2008-05-16 22:15:45
David Masury
Re: Gauge replacement
You can get the parts you need from Westmarine....it is a stock part, the sending unit and the gauge, replace both items.   You do need to modify the sending unit jus a touch...shorten the support rod and turn the pivot block 90 degreees.
'IRIS'
1975 C&C 27 Mk lll
Hull # 453
'IRIS'
1975 C&C 27 Mk lll
Hull # 453
