#1 2007-02-11 05:12:04
#1 Genoa for Sale - Mark 1 Tall Mast/Mark 3
I have a HOOD Genoa, used 2 seasons, we had it on our Mark 1 Tall Mast (REIVER), which we sold  in 2004(it was either put in baby seats or take a break from sailing).  Long story, we discovered during our recent move that we still had a 2 year/season old #1 Genoa. The sail is fitted for roller furling (HARKEN Model O) and is in excellent condition New cost $1100 - first $500 OBO takes it. Give me a call (613) 687-8576
#2 2007-02-12 01:58:41
Re: #1 Genoa for Sale - Mark 1 Tall Mast/Mark 3
I assume this is your 150 or 150+?    my email (finsol@si.rr.com) Roald
#3 2007-02-12 07:10:48
If I remember correctly it was the 170 (largest that I could have based on C&C 27 regs)
#4 2007-02-13 05:43:26
You indicate tall mast Mark 1.  I'm not familiar with that spec. is your mast the same as a Mark III (i.e. I=37').   Do you know the exact luff length?  I'm going to see if I can find out what size luff tape a Harken Model 0 uses, unless you alread know?
Chris
#5 2007-02-13 09:10:37
Chris,
The mast on my Mark 1 was 2 1/2 feet shorter than the Mark 3.  If you are intetersted in the sail, let me know andfI will pull it out and measure it.  I can also take pics of it for you
#6 2007-02-14 05:08:38
Sounds like your mast is 2.5' shorter than mine, which likely makes the sail luff about 2.4' shorter than what I need.  If yours is a deck sweeper (unlikely with the furling gear) it might be ok on my boat, as I have an Ultrafurl that means the tack sits about 12" off the deck at the bow.  My luff length should be about 35.7'.
#7 2007-02-14 07:17:04
Chris:
The sail was designed as a "deck sweeper" - it was our #1 for racing.  The HARKEN O system allows you to either use the foil or the roller furling - the sail was designed to use the foil.  We used it with the roller furling a few times.  When we raced, it was tacked to the stem plate and ran to 6 inches of the head. When on the roller furling, she fit head to furler.  It would fit a Mark 3 will little difficulty, but you may find it is 1 - 1 1/2 feet short of the masthead.
Let me know if you wantthe full measurements, I will pull it out and send them to you.
Dave
#8 2007-02-14 22:48:59
Sounds like it may be very interesting.  Hate to ask you to pull it all out......but the luff length would be nice to know.  I haven't been able to find what size luff tape (i.e. #5 or #6) that a Harken 0 uses, any ideas?
#9 2007-02-15 01:00:13
Manual for my Harken 0 shows No. 6 (6/32" or 5mm) luff tape.
#10 2007-02-15 06:01:14
Chris,
I wil pull it out tonight and measure it up.  I will take some pics as well (head, tack and clew).  Send me you e-mail address and I will send you the pics
#11 2007-02-17 03:54:15
Sail measurements are as follows:
Foot = 19'6"
Luff = 33'7"
Leech = 32'7"
The sail was a 163% for a Mark 1 (Tall Rig)
Pictures are available if you send me your e-mail address
#12 2007-02-21 02:55:48
Thanks for all the effort Dave.  Sorry to say that does make the sail about 4' to short on the luff to fit my boat, I think it would look and preform rather poorly.
To Bad I could have used a new head sail.
#13 2007-02-21 06:25:19
Hi Dave , if still for sale I am very interested . Regards , Gene Bruce   gbruce@nsc.ca  or cell 613-293-8934
