#1 2006-08-18 10:45:55
MK V Waste Cap Replacement
Hello,
We left the old cap a the pump out station...
The fitting manufacture is R&C from New Zealand and the cap appears to be a little smaller that the 1.5" caps that are available. The treading also looks to be a bit tighter. Anyone know where to find one of these? I'm close to replacing the whole fitting but would like to avoid it if possibe.
Dave
<A href="mailto:dave@taniscomm.com">dave@taniscomm.com</A></SPAN>
#2 2006-08-19 12:19:42
Re: MK V Waste Cap Replacement
I wold replace the whole thing, I found that many marina pump outs did not fit the MKV waste fitting, as the screw in is an off size. If the Pump out did not have the Red Rubber (Funnel/Cone) adapter, a pump out was not possible.
Regards
Cameron
