#1 2006-05-17 02:04:27
Second Jib Halyard
Greetings from Northwestern Ontario,
I have a Mk III tall rig mast with two pulleys on the fore section at the top which I assume are there to accomodate two jib halyards for the twin foil forestay.  I fished a line throught the mast but now have to install a second exit plate on the lower part of the mast for the additonal halyard.  Any suggestions on location of this plate to minimize conflict with all the other goodies inside and outside the mast.
Thanks in advance
The Marshall's
Hotel California
Dryden  Ontario
#2 2006-05-18 00:22:34
foroadmin
Administrator
Re: Second Jib Halyard
Assuming that your original through-plate is above a winch on the port side of the mast, our secondary halyard passes through a plate about 3-4 inches below and about 1.5 inches aftward of the first.  I've not experienced any conflict in this setup, but we don't often try headsail changes and very seldom need the second.
Gord.
