#1 2005-09-18 23:54:34
ignition switch
My MKII ignition switch (push/pull) is working intermittenly.  Does anyone know of a OEM replacement?  I am about to start looking in the catalogs, thought someone might have a solution.
#2 2005-09-19 00:19:14
Re: ignition switch
West Marine sells a "Switch - Off/On, gasket sealed" that is visually and functionally identical to the pull switches on my Mk IV. It's made by Cole-Hersee, who apparently make very reliable gear.
#3 2005-09-19 03:51:35
Re: ignition switch
Thanks for the info.  By the way I appreciate reading your input on various problems people encounter as they renovate their 27's.  Thanks again.
